Salta al contenuto principale
ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement
Cosa ti serve
  1. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement, USB and Power Circuit Board: passo 1, immagine 1 di 2 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement, USB and Power Circuit Board: passo 1, immagine 2 di 2
    • Remove the ten 10.7 mm screws using a Phillips #0 screwdriver from the back of the laptop.
  2. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: passo 2, immagine 1 di 2 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Heavy-Duty Spudger
    Compra
  3. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: passo 3, immagine 1 di 2 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: passo 3, immagine 2 di 2
    • Remove the two 4.7 mm screws with the Phillips #0 screwdriver.
  4. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: passo 4, immagine 1 di 3 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: passo 4, immagine 2 di 3 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: passo 4, immagine 3 di 3
    • Using a spudger or fingernail, flip up the white plastic latch securing the ribbon cable.
    • After the latch is released remove the ribbon cable and clear it from the board.
  5. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: passo 5, immagine 1 di 2 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: passo 5, immagine 2 di 2
    • Remove the board itself by carefully pulling the board up then away from the rest of the computer.
Conclusione
Wyatt Scott
Membro da: 11/01/18
136 Reputazione
1 Guida realizzata
IUPUI, Team S2-G3, Harley Fall 2018 Membro di IUPUI, Team S2-G3, Harley Fall 2018
IUPUI-HARLEY-F18S2G3
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 998
