Introduzione
In this guide, we will show you how to access and remove the battery of the ASUS Transformer Book Flip TP500LA. This guide will assist you in replacing your dysfunctional battery with a new one.
Cosa ti serve
Remove the ten 10 mm Phillips #0 screws found on the computer's back case.
Attrezzo utilizzato in questo passaggio:Heavy-Duty Spudger$4.99
Slide a heavy-duty spudger between the back case and the computer.
Slowly work around the edges to undo the clips to fully separate the back case from the computer.
Gently lift off the back case.
Slide a heavy-duty spudger into the ZIF connector and gently flip up the retaining flap to open the connector.
Pull the blue tab to remove the ribbon.
Altre 14 persone hanno completato questa guida.
