Introduzione
This guide is for replacing the battery of the ASUS TUF Gaming FX505DY, a 3 cell 48 Watt-hour lithium-ion internal battery.
Despite the device's MIL-STD-810G rating, sudden impacts or a puncture can damage or destroy the battery. Batteries can also fail to excessive heat or after a long service life inhibits charging. A faulty battery will result in a short or nonexistent battery life, an inability to charge, or damage to the device. Check the troubleshooting page first to make sure it is not a different issue.
Watch out for indications of damage, including swelling, cracking, leaking, or burns. If damage is present or suspected, perform this repair wearing fire-resistant or natural-fiber clothes. Keep your work area clear of flammable materials and have a working Class B fire extinguisher or other suitable agent on hand. Do not use water to extinguish a lithium-ion battery fire.
Make sure to fully shut down the device and unplug any chargers and peripherals before beginning.
Cosa ti serve
Turn off the laptop.
Disconnect the charging cable.
Flip the laptop so the back is facing up.
Using an ESD-safe spudger, disconnect the battery connector by pulling the plug away from its port.
