Salta al contenuto principale
ASUS TUF Gaming FX505DY Back Case Replacement
Cosa ti serve
  1. ASUS TUF Gaming FX505DY Back Case Replacement, Back Case: passo 1, immagine 1 di 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY Back Case Replacement: passo 2, immagine 1 di 2 ASUS TUF Gaming FX505DY Back Case Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY Back Case Replacement: passo 3, immagine 1 di 2 ASUS TUF Gaming FX505DY Back Case Replacement: passo 3, immagine 2 di 2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY Back Case Replacement: passo 4, immagine 1 di 2 ASUS TUF Gaming FX505DY Back Case Replacement: passo 4, immagine 2 di 2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 40
Tutti i Tempi: 997
