Salta al contenuto principale
ASUS ROG Strix GL503VD-DB71 Fan Replacement
Cosa ti serve
  1. ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: passo 1, immagine 1 di 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: passo 1, immagine 2 di 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: passo 1, immagine 3 di 3
    • Flip the laptop over so that the bottom is facing up.
    • Remove the ten screws around the edges and in the center of the back case with a Phillips #1 screwdriver.
  2. ASUS ROG Strix GL503VD-DB71 Fan Replacement: passo 2, immagine 1 di 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: passo 2, immagine 2 di 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: passo 2, immagine 3 di 3
    • Pry up the triangular service cover with a plastic opening tool.
    • Remove the single Phillips #1 screw beneath the cover.
    • Pry up the remainder of the back cover with a plastic opening tool and remove the back cover.
  3. ASUS ROG Strix GL503VD-DB71 Fan Replacement: passo 3, immagine 1 di 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: passo 3, immagine 2 di 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: passo 3, immagine 3 di 3
    • Remove the four screws from the fans with a Phillips #1 screwdriver.
    • Unplug each of the fan connectors from the motherboard.
    • Remove each fan by lifting it from the case.
Conclusione
2 Commenti
Hi! I have a GL503VD-EB72 and my fans look ever so slightly different. Trying to replace one right now but I’m seeing a lot of variety in what’s available on eBay and amazon…How can I tell if my fans are 5V or 12V?
Kirsten M - Replica
WTF i can find a 12 V for my GL503V
mrparisalexandre - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 40
Tutti i Tempi: 4,522
