Salta al contenuto principale
ASUS ROG Spatha X Scroll Wheel Replacement
Cosa ti serve
  1. ASUS ROG Spatha X Scroll Wheel Replacement, Mouse Cover: passo 1, immagine 1 di 3 ASUS ROG Spatha X Scroll Wheel Replacement, Mouse Cover: passo 1, immagine 2 di 3 ASUS ROG Spatha X Scroll Wheel Replacement, Mouse Cover: passo 1, immagine 3 di 3
    • Make sure the mouse is unplugged and the power switch on the underside is set to the off position.
    • Use the pointed edge of a spudger to remove the four soft rubber covers on the underside of the mouse.
    • Use the included Torx screwdriver, or a T3 Torx screwdriver, to remove the four 4 mm screws.
  2. ASUS ROG Spatha X Scroll Wheel Replacement: passo 2, immagine 1 di 2 ASUS ROG Spatha X Scroll Wheel Replacement: passo 2, immagine 2 di 2
    • Lift the upper mouse cover up and off.
  3. ASUS ROG Spatha X Scroll Wheel Replacement, Scroll Wheel: passo 3, immagine 1 di 3 ASUS ROG Spatha X Scroll Wheel Replacement, Scroll Wheel: passo 3, immagine 2 di 3 ASUS ROG Spatha X Scroll Wheel Replacement, Scroll Wheel: passo 3, immagine 3 di 3
    • Remove the Phillips screw securing the ribbon cable scroll wheel.
    • Disconnect the ribbon cable from the scroll wheel.
  4. ASUS ROG Spatha X Scroll Wheel Replacement: passo 4, immagine 1 di 3 ASUS ROG Spatha X Scroll Wheel Replacement: passo 4, immagine 2 di 3 ASUS ROG Spatha X Scroll Wheel Replacement: passo 4, immagine 3 di 3
    • There is a plastic axle holding the scroll wheel in place. It is cinched into a plastic housing unit towards the right side of the mouse (towards the pinky rest).
    • Use one hand to gently pull the housing for the axle away from the scroll wheel as you simultaneously use the other hand to pull up and away from the housing unit.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
cgrabowski1
Membro da: 03/21/25
671 Reputazione
5 Guide realizzate
1Commento della guida
Easy replacement but good luck finding the part. It's not sold ANYWHERE.
Tyler Pratt - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 72
Tutti i Tempi: 408
