Salta al contenuto principale
ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement
Cosa ti serve
  1. ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement, Internal Hard Drive: passo 1, immagine 1 di 1
    • Remove the six screws on the back of the laptop using a Phillips screwdriver.
    • Remove the back casing being held on by the one single screw. First lift the casing at the edge where the screw once was, then carefully lift at the rest of the edges to loosen the casing. Pull the casing towards the edge where the screw was.
  2. ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: passo 2, immagine 1 di 2 ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: passo 2, immagine 2 di 2
    • Locate the metal hard drive bay in the bottom left corner of the laptop.
    • Remove the two black screws securing the metal hard drive to the plastic.
    • Pull the tab to the right and slide to unseat the hard drive bay, then lift out.
  3. ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: passo 3, immagine 1 di 2 ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: passo 3, immagine 2 di 2
    • Remove the two screws on the sides of the hard drive panel, shown circled. Repeat for the other side.
    • Replace the hard drive.
Conclusione
Altre 3 persone hanno completato questa guida.
Logan Smith
Membro da: 01/25/17
783 Reputazione
4 Guide realizzate
Cal Poly, Team 8-3, Banghart Winter 2017 Membro di Cal Poly, Team 8-3, Banghart Winter 2017
CPSU-BANGHART-W17S8G3
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 972
