Introduzione
The RAM is where the working memory of the computer is and replacing it will allow your computer to perform better.
Replacing the RAM is the easiest and cheapest way to help speed up a computer.
Parti
Nessuna parte richiesta.
  1. Make sure you completely power down the computer before beginning this process.
    • Make sure you completely power down the computer before beginning this process.
    • With your finger, push this slide to the right. The battery should pop out of place.
  2. Pull the battery out of its place gently.
    • Pull the battery out of its place gently.
  3. Open flap in center and underneath you will find a screw, remove the 5.2mm screw with a Phillips #0 screwdriver. Open flap in center and underneath you will find a screw, remove the 5.2mm screw with a Phillips #0 screwdriver.
    • Open flap in center and underneath you will find a screw, remove the 5.2mm screw with a Phillips #0 screwdriver.
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. Once the screw is out, pull on the plastic tab to pull off the plastic cover. Once the screw is out, pull on the plastic tab to pull off the plastic cover.
    • Once the screw is out, pull on the plastic tab to pull off the plastic cover.
  6. This exposes two hard drive caddies.
    • This exposes two hard drive caddies.
    • This also exposes two RAM slots.
  7. Push the metal tabs outward that are located on both sides of the top ram.
    • Push the metal tabs outward that are located on both sides of the top ram.
    • Remove the RAM from the slot.
    • Repeat with bottom RAM
  8. Align new RAM's key with the slot. Place RAM in slot at a 45 degree angle downward, until the teeth are hidden inside of the socket itself.
    • Align new RAM's key with the slot.
    • Place RAM in slot at a 45 degree angle downward, until the teeth are hidden inside of the socket itself.
    • Push down on RAM until a clicking sound is heard, meaning it is in place.
    • Repeat with top RAM
Conclusione
To reassemble your device, follow Steps 1-4 in reverse order.
Ellie Moran
Membro da: 22/01/2018
142 Reputazione
1 Guida realizzata
Cal Poly, Team S11-G5, Banghart Winter 2018 Membro di Cal Poly, Team S11-G5, Banghart Winter 2018
CPSU-BANGHART-W18S11G5
4 Membri
5 Guide realizzate
What about replacing the two internal RAM Modules?
Latiron London - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 143
