Salta al contenuto principale
ASUS Q536F Screen Replacement
Cosa ti serve
  1. ASUS Q536F Screen Replacement, Back Panel: passo 1, immagine 1 di 2 ASUS Q536F Screen Replacement, Back Panel: passo 1, immagine 2 di 2
    • Remove ten 2 mm screws using a Phillips #0 screwdriver.
    • Remove the screw in the center using a T4 Torx screwdriver.
    • Use an iFixit opening tool to pry open the back panel.
    • It's normal to hear some cracking, but proceed with caution.
  2. ASUS Q536F Screen Replacement, Display Assembly: passo 2, immagine 1 di 1
    • Remove the six 2 mm screws from the hinges using a Phillips #0 screwdriver.
  3. ASUS Q536F Screen Replacement: passo 3, immagine 1 di 3 ASUS Q536F Screen Replacement: passo 3, immagine 2 di 3 ASUS Q536F Screen Replacement: passo 3, immagine 3 di 3
    • Using your fingers, unplug the two power cables connecting the display to the motherboard.
    • Remove the display assembly from the laptop.
  4. ASUS Q536F Screen Replacement, Screen: passo 4, immagine 1 di 3 ASUS Q536F Screen Replacement, Screen: passo 4, immagine 2 di 3 ASUS Q536F Screen Replacement, Screen: passo 4, immagine 3 di 3
    • Potential for device damage: Beneath the screen border is a sticky adhesive. Take your time and exercise caution when removing to avoid damaging it.
    • Use an iOpener to help loosen the adhesive on the screen.
    • Gently pry the bottom right corner of the screen's border and remove the sticky screen cover.
    • Use the opening tool around the entire display to ensure you cut as much adhesive as possible.
  5. ASUS Q536F Screen Replacement: passo 5, immagine 1 di 1
    • Carefully remove the screen from the rest of the display.
    • The new screen should come with the sticky adhesive.
Conclusione
Adra Ledward
Membro da: 09/07/23
557 Reputazione
5 Guide realizzate
Gateway, Team 88-8, Gonzalez Fall 2023 Membro di Gateway, Team 88-8, Gonzalez Fall 2023
GCC-GONZALEZ-F23S88G8
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 24
Tutti i Tempi: 155
