Salta al contenuto principale
ASUS Q536F Battery Replacement
Cosa ti serve
  1. ASUS Q536F Battery Replacement, Back Panel: passo 1, immagine 1 di 2 ASUS Q536F Battery Replacement, Back Panel: passo 1, immagine 2 di 2
    • Remove ten 2 mm screws using a Phillips #0 screwdriver.
    • Remove the screw in the center using a T4 Torx screwdriver.
    • Use an iFixit opening tool to pry open the back panel.
    • It's normal to hear some cracking, but proceed with caution.
  2. ASUS Q536F Battery Replacement, Battery: passo 2, immagine 1 di 2 ASUS Q536F Battery Replacement, Battery: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the four 2 mm screws from the battery using a Phillips #1 screwdriver.
    • Detach the battery cable from the motherboard using a pair of tweezers.
  3. ASUS Q536F Battery Replacement: passo 3, immagine 1 di 3 ASUS Q536F Battery Replacement: passo 3, immagine 2 di 3 ASUS Q536F Battery Replacement: passo 3, immagine 3 di 3
    • Unhinge the fan cable using your fingers or a pair of tweezers.
    • Remove the battery from its slot.
    • There should be no resistance from any cable wiring at this point. If there happens to be resistance, make sure to double check and confirm nothing is being pulled.
Conclusione
Gateway, Team 88-8, Gonzalez Fall 2023 Membro di Gateway, Team 88-8, Gonzalez Fall 2023
GCC-GONZALEZ-F23S88G8
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 72
Tutti i Tempi: 626
