Salta al contenuto principale
ASUS Q405U Wifi Card Replacement
Cosa ti serve
  1. ASUS Q405U Wifi Card Replacement, Back Cover: passo 1, immagine 1 di 1
    • Using the Phillips #1 screwdriver, remove eleven (11) 1.5 mm screws from the back cover.
  2. ASUS Q405U Wifi Card Replacement: passo 2, immagine 1 di 1
    • Pull the back cover off of your laptop. Use a spudger to help pry it off of the device.
  3. ASUS Q405U Wifi Card Replacement: passo 3, immagine 1 di 3 ASUS Q405U Wifi Card Replacement: passo 3, immagine 2 di 3 ASUS Q405U Wifi Card Replacement: passo 3, immagine 3 di 3
    • Disconnect the 4 wires attached from the keyboard side of laptop to the screen side of laptop by pulling them out of their sockets on one end (as shown in picture).
  4. ASUS Q405U Wifi Card Replacement, Battery: passo 4, immagine 1 di 1
    • Using the Phillips #1 screwdriver, remove the four 1.5 mm screws securing the battery to the device.
  5. ASUS Q405U Wifi Card Replacement: passo 5, immagine 1 di 1
    • Once all screws are removed, lift the battery out from the base of the computer.
  6. ASUS Q405U Wifi Card Replacement, Wifi Card: passo 6, immagine 1 di 1
    • Using the Phillips #1 screwdriver, remove the 0.8 mm screw securing the Wi-Fi card to the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 20
Tutti i Tempi: 411
