Introduzione
The RAM, (random access memory), helps process the data of your computer to increase speed. Issues with it are very serious, such as intermittent crashing or preventing the computer’s ability to turn on. which can be quite frustrating for the user as it can share symptoms with other failing components. This guide will go through with you step by step on how to replace the RAM of your ASUS Q405U.
Cosa ti serve
Using the Phillips #1 screwdriver, remove eleven (11) 1.5 mm screws from the back cover.
RAM is what is identified in picture. Unscrew the 0.8mm screw to remove it from socket.
