Salta al contenuto principale
ASUS Q405U RAM Replacement
Cosa ti serve
  1. ASUS Q405U RAM Replacement, Back Cover: passo 1, immagine 1 di 1
    • Using the Phillips #1 screwdriver, remove eleven (11) 1.5 mm screws from the back cover.
  2. ASUS Q405U RAM Replacement: passo 2, immagine 1 di 1
    • Pull the back cover off of your laptop. Use a spudger to help pry it off of the device.
  3. ASUS Q405U RAM Replacement: passo 3, immagine 1 di 3 ASUS Q405U RAM Replacement: passo 3, immagine 2 di 3 ASUS Q405U RAM Replacement: passo 3, immagine 3 di 3
    • Disconnect the 4 wires attached from the keyboard side of laptop to the screen side of laptop by pulling them out of their sockets on one end (as shown in picture).
  4. ASUS Q405U RAM Replacement, RAM: passo 4, immagine 1 di 1
    • RAM is what is identified in picture. Unscrew the 0.8mm screw to remove it from socket.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 33
Tutti i Tempi: 977
