Salta al contenuto principale
ASUS Q400A-BHI7N03 Screen Replacement
Cosa ti serve
  1. ASUS Q400A-BHI7N03 Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Flip the laptop on its back side with the battery facing toward you.
    • Slide the tabs with lock/unlock symbol, to the unlock position.
    • Grabbing the top edge of the battery, lift upward to relieve the battery from its slot.
  2. ASUS Q400A-BHI7N03 Screen Replacement: passo 2, immagine 1 di 1
    • Lift the two black plastic circles off the screen using the plastic spudger.
    • Unscrew the two 8mm Phillips #0 screws.
  3. ASUS Q400A-BHI7N03 Screen Replacement: passo 3, immagine 1 di 1
    • Pry the front edges of the screen using the spudger.
  4. ASUS Q400A-BHI7N03 Screen Replacement: passo 4, immagine 1 di 1
    • Remove the four black 8mm Phillips #0 screws and set them aside.
  5. ASUS Q400A-BHI7N03 Screen Replacement: passo 5, immagine 1 di 1
    • Pry the LCD from the front frame.
  6. ASUS Q400A-BHI7N03 Screen Replacement: passo 6, immagine 1 di 1
    • Pull the gold ribbon cable to disconnect the screen from the laptop.
Conclusione
Altre 3 persone hanno completato questa guida.
IUPUI, Team S1-G3, Harley Fall 2018 Membro di IUPUI, Team S1-G3, Harley Fall 2018
IUPUI-HARLEY-F18S1G3
3 Membri
2 Guide realizzate
Un commento
Can you tell me what is the part number and description for the display, I need to order one to replace mi ASUS broken screen. Thanks in advance...!!!
Daniel Ventura Avalos - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 550
