Salta al contenuto principale
ASUS Q324UA-BHI7T17 CPU Fan Replacement
Cosa ti serve
  1. ASUS Q324UA-BHI7T17 CPU Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Remove all 10 Phillips screws on the backplate.
    • All 10 screws are 0.55 inches and 20 mm in diameter.
  2. ASUS Q324UA-BHI7T17 CPU Fan Replacement: passo 2, immagine 1 di 2 ASUS Q324UA-BHI7T17 CPU Fan Replacement: passo 2, immagine 2 di 2
    • Carefully remove the backplate using the plastic opening tool.
  3. ASUS Q324UA-BHI7T17 CPU Fan Replacement: passo 3, immagine 1 di 1
    • Locate the battery near the bottom.
  4. ASUS Q324UA-BHI7T17 CPU Fan Replacement: passo 4, immagine 1 di 1
    • Next, lift up the battery connector from the laptop in the upper left side of the battery, using tweezers or spudger.
    • Make sure to complete this step with caution, because if the battery is not unplugged, the motherboard may shock you.
  5. ASUS Q324UA-BHI7T17 CPU Fan Replacement: passo 5, immagine 1 di 2 ASUS Q324UA-BHI7T17 CPU Fan Replacement: passo 5, immagine 2 di 2
    • Remove the six screws holding in the battery with a Phillips #0 screwdriver.
    • Once battery is lifted out and removed, proper dispose of the old battery.
    • Each screw is 0.5 cm in length and 0.5 cm in diameter.
  6. ASUS Q324UA-BHI7T17 CPU Fan Replacement, CPU Fan: passo 6, immagine 1 di 2 ASUS Q324UA-BHI7T17 CPU Fan Replacement, CPU Fan: passo 6, immagine 2 di 2
    • Using a Phillips #0 screwdriver remove the six screws holding the CPU Fan and Heatsink in place.
    • All six screws are 0.4 cm in length and have a 0.5 cm head diameter.
  7. ASUS Q324UA-BHI7T17 CPU Fan Replacement: passo 7, immagine 1 di 2 ASUS Q324UA-BHI7T17 CPU Fan Replacement: passo 7, immagine 2 di 2
    • Next, carefully remove the sliding connector that connect the CPU Fan and the laptop together using the tweezers.
  8. ASUS Q324UA-BHI7T17 CPU Fan Replacement: passo 8, immagine 1 di 1
    • Remove the CPU Fan and Heatsink by simply lifting upwards.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,036
