Salta al contenuto principale
ASUS Q302L Motherboard Replacement
Cosa ti serve
  1. ASUS Q302L Motherboard Replacement, Back Case: passo 1, immagine 1 di 1
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Motherboard Replacement: passo 2, immagine 1 di 3 ASUS Q302L Motherboard Replacement: passo 2, immagine 2 di 3 ASUS Q302L Motherboard Replacement: passo 2, immagine 3 di 3
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Motherboard Replacement: passo 3, immagine 1 di 1
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Motherboard Replacement, Battery: passo 4, immagine 1 di 1
    • Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
  5. ASUS Q302L Motherboard Replacement: passo 5, immagine 1 di 3 ASUS Q302L Motherboard Replacement: passo 5, immagine 2 di 3 ASUS Q302L Motherboard Replacement: passo 5, immagine 3 di 3
    • Gently wedge a plastic opening tool under the connector.
    • Pry only on the connector not the socket itself or you risk damage to the motherboard.
    • Carefully lift the connector up away from the socket to disconnect it.
  6. ASUS Q302L Motherboard Replacement: passo 6, immagine 1 di 2 ASUS Q302L Motherboard Replacement: passo 6, immagine 2 di 2
    • Once the screws and connector are removed, simply pull out the battery from its place.
  7. ASUS Q302L Motherboard Replacement, Fan: passo 7, immagine 1 di 2 ASUS Q302L Motherboard Replacement, Fan: passo 7, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove all three 4mm screws around the fan.
    • Using the same screw driver, remove the four 4mm screws from the part of the fan that is above the processor.
  8. ASUS Q302L Motherboard Replacement: passo 8, immagine 1 di 3 ASUS Q302L Motherboard Replacement: passo 8, immagine 2 di 3 ASUS Q302L Motherboard Replacement: passo 8, immagine 3 di 3
    • Gently wedge two plastic prying tools on both sides of the black part of the connector.
    • Carefully pull out the connector from its socket.
  9. ASUS Q302L Motherboard Replacement: passo 9, immagine 1 di 2 ASUS Q302L Motherboard Replacement: passo 9, immagine 2 di 2
    • Once all screws and the connector are removed, you can safely pull the fan out of its place.
  10. ASUS Q302L Motherboard Replacement, Motherboard: passo 10, immagine 1 di 3 ASUS Q302L Motherboard Replacement, Motherboard: passo 10, immagine 2 di 3 ASUS Q302L Motherboard Replacement, Motherboard: passo 10, immagine 3 di 3
    • Peel back the adhered strip to expose the black and white connections.
    • Pop the connections off the fixtures.
  11. ASUS Q302L Motherboard Replacement: passo 11, immagine 1 di 2 ASUS Q302L Motherboard Replacement: passo 11, immagine 2 di 2
    • Grasp the plastic tab of each connector with your fingers.
    • Firmly pull up, releasing the connectors one at a time.
  12. ASUS Q302L Motherboard Replacement: passo 12, immagine 1 di 2 ASUS Q302L Motherboard Replacement: passo 12, immagine 2 di 2
    • As in Step 8, gently pry out both sides of the white connector and pull out the connector.
  13. ASUS Q302L Motherboard Replacement: passo 13, immagine 1 di 3 ASUS Q302L Motherboard Replacement: passo 13, immagine 2 di 3 ASUS Q302L Motherboard Replacement: passo 13, immagine 3 di 3
    • For each of the four marked connectors, gently insert a thin prying tool between the blue ribbon and grey tab.
    • Gently apply upward pressure evenly across the length of the tab.
    • Once the tab has snapped backwards, remove the blue ribbon.
  14. ASUS Q302L Motherboard Replacement: passo 14, immagine 1 di 1
    • Using the Phillips #00 screwdriver, remove the ten 4mm screws.
  15. ASUS Q302L Motherboard Replacement: passo 15, immagine 1 di 2 ASUS Q302L Motherboard Replacement: passo 15, immagine 2 di 2
    • Lift the Hinge gently up.
    • Lightly grasp the motherboard.
    • Lift the marked corner of the board first, then slide the corner of the board out from under the back corner of the case.
    • Place new thermal paste beneath the heatsink on the new motherboard.
Conclusione
Altre 2 persone hanno completato questa guida.
IUPUI, Team S2-G4, Harley Spring 2019 Membro di IUPUI, Team S2-G4, Harley Spring 2019
IUPUI-HARLEY-S19S2G4
3 Membri
2 Guide realizzate
Un commento
Where can I get a replacement motherboard?
Alex - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,280
