Salta al contenuto principale
ASUS Q302L Fan Replacement
Cosa ti serve
  1. ASUS Q302L Fan Replacement, Back Case: passo 1, immagine 1 di 1
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Fan Replacement: passo 2, immagine 1 di 3 ASUS Q302L Fan Replacement: passo 2, immagine 2 di 3 ASUS Q302L Fan Replacement: passo 2, immagine 3 di 3
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Fan Replacement: passo 3, immagine 1 di 1
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Fan Replacement, Fan: passo 4, immagine 1 di 2 ASUS Q302L Fan Replacement, Fan: passo 4, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove all three 4mm screws around the fan.
    • Using the same screw driver, remove the four 4mm screws from the part of the fan that is above the processor.
  5. ASUS Q302L Fan Replacement: passo 5, immagine 1 di 3 ASUS Q302L Fan Replacement: passo 5, immagine 2 di 3 ASUS Q302L Fan Replacement: passo 5, immagine 3 di 3
    • Gently wedge two plastic prying tools on both sides of the black part of the connector.
    • Carefully pull out the connector from its socket.
  6. ASUS Q302L Fan Replacement: passo 6, immagine 1 di 2 ASUS Q302L Fan Replacement: passo 6, immagine 2 di 2
    • Once all screws and the connector are removed, you can safely pull the fan out of its place.
Conclusione
USF Tampa, Team S13-G4, Cagle Spring 2017 Membro di USF Tampa, Team S13-G4, Cagle Spring 2017
USFT-CAGLE-S17S13G4
3 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 767
