Salta al contenuto principale
ASUS Padfone X mini Station Speaker Replacement
Cosa ti serve
  1. ASUS Padfone X mini Station Speaker Replacement, Battery: passo 1, immagine 1 di 1
    • Insert the plastic opening tool between the edge of the screen and the back cover.
    • Gently pry them apart. Use hands to pull them apart if necessary.
  2. ASUS Padfone X mini Station Speaker Replacement: passo 2, immagine 1 di 2 ASUS Padfone X mini Station Speaker Replacement: passo 2, immagine 2 di 2
    • Remove the three pieces of tape that secure the battery and its wires. Peel gently so you don’t damage any wires.
  3. ASUS Padfone X mini Station Speaker Replacement: passo 3, immagine 1 di 3 ASUS Padfone X mini Station Speaker Replacement: passo 3, immagine 2 di 3 ASUS Padfone X mini Station Speaker Replacement: passo 3, immagine 3 di 3
    • Disconnect the ribbon from the motherboard by gently pulling with your fingers.
    • Using the opening tools, pry the battery off of the adhesive.
    • Be careful not to pull the battery out right away. The ribbon cable is tucked beneath another wire.
  4. ASUS Padfone X mini Station Speaker Replacement, Speaker: passo 4, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the three 2.5mm screws that secure the speaker case to the motherboard.
    • Remove all tape covering the screws before removing them.
  5. ASUS Padfone X mini Station Speaker Replacement: passo 5, immagine 1 di 3 ASUS Padfone X mini Station Speaker Replacement: passo 5, immagine 2 di 3 ASUS Padfone X mini Station Speaker Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to remove the three pieces of tape that are covering the metal.
    • Insert the metal spudger beneath the speaker case and wedge it upwards to remove speaker case from the device body.
  6. ASUS Padfone X mini Station Speaker Replacement: passo 6, immagine 1 di 2 ASUS Padfone X mini Station Speaker Replacement: passo 6, immagine 2 di 2
    • Use tweezers to detach the connecter from the motherboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 170
