Salta al contenuto principale
ASUS Padfone X mini Station Front Camera Replacement
Cosa ti serve
  1. ASUS Padfone X mini Station Front Camera Replacement, Front Camera Lens: passo 1, immagine 1 di 1
    • Insert the plastic opening tool between the edge of the screen and the back cover.
    • Gently pry them apart. Use hands to pull them apart if necessary.
  2. ASUS Padfone X mini Station Front Camera Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the three 2.5mm screws that secure the speaker case to the motherboard.
    • Remove all tape covering the screws before removing them.
  3. ASUS Padfone X mini Station Front Camera Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to remove cover sticker on the dock station.
  4. ASUS Padfone X mini Station Front Camera Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #000 screwdriver to remove the six 0.6mm screws that secure the dock station case to the motherboard.
  5. ASUS Padfone X mini Station Front Camera Replacement: passo 5, immagine 1 di 1
    • Flip the device upwards.
    • Gently push the right side of motherboard down away from the dock station.
    • Do not push the motherboard so hard as it is still attached to a connector. Excessive force applied might cause external damage to it.
  6. ASUS Padfone X mini Station Front Camera Replacement: passo 6, immagine 1 di 2 ASUS Padfone X mini Station Front Camera Replacement: passo 6, immagine 2 di 2
    • Use tweezers to detach the camera from the motherboard.
Conclusione
Un commento
I can not get my back off the device at the top of it it doesn't want to complete separate.
Jannell A McDonald - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 176
