Salta al contenuto principale
ASUS Padfone X mini Station Battery Replacement
Cosa ti serve
  1. ASUS Padfone X mini Station Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Insert the plastic opening tool between the edge of the screen and the back cover.
    • Gently pry them apart. Use hands to pull them apart if necessary.
  2. ASUS Padfone X mini Station Battery Replacement: passo 2, immagine 1 di 2 ASUS Padfone X mini Station Battery Replacement: passo 2, immagine 2 di 2
    • Remove the three pieces of tape that secure the battery and its wires. Peel gently so you don’t damage any wires.
  3. ASUS Padfone X mini Station Battery Replacement: passo 3, immagine 1 di 3 ASUS Padfone X mini Station Battery Replacement: passo 3, immagine 2 di 3 ASUS Padfone X mini Station Battery Replacement: passo 3, immagine 3 di 3
    • Disconnect the ribbon from the motherboard by gently pulling with your fingers.
    • Using the opening tools, pry the battery off of the adhesive.
    • Be careful not to pull the battery out right away. The ribbon cable is tucked beneath another wire.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 498
