Salta al contenuto principale
ASUS PadFone X Station USB Charging Port Replacement
Cosa ti serve
  1. ASUS PadFone X Station USB Charging Port Replacement, Back Cover: passo 1, immagine 1 di 2 ASUS PadFone X Station USB Charging Port Replacement, Back Cover: passo 1, immagine 2 di 2
    • Using the plastic opening tools, insert it into the edge and pry open.
    • Use hands to help pull the back off from the front if needed.
  2. ASUS PadFone X Station USB Charging Port Replacement, Check USB Charging Port for water damage: passo 2, immagine 1 di 2 ASUS PadFone X Station USB Charging Port Replacement, Check USB Charging Port for water damage: passo 2, immagine 2 di 2
    • Locate CON2002
    • Check water indicator on USB Charging Port
    • A white indicator means there is no water damage. A red indicator means there was water damage.
  3. ASUS PadFone X Station USB Charging Port Replacement, Removing Charging Port: passo 3, immagine 1 di 1
    • Locate and remove three Phillips screws
  4. ASUS PadFone X Station USB Charging Port Replacement, Disconnect E893821: passo 4, immagine 1 di 1
    • Use a pair of tweezers to disconnect E893821
Conclusione
Altre 4 persone hanno completato questa guida.
Daniel
Membro da: 10/07/14
338 Reputazione
2 Guide realizzate
USF Tampa, Team 7-4, Leahy Fall 2014 Membro di USF Tampa, Team 7-4, Leahy Fall 2014
USFT-LEAHY-F14S7G4
4 Membri
8 Guide realizzate
Un commento
Does anyone have any idea where a replacement USB port can be found. Mine isnt water damaged but rather one of the pins broke off and its hanging out of the cable. Now the phone will not charge.
rich - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,694
