Parti
Nessuna parte richiesta.
Using the plastic opening tools, insert it into the edge and pry open.
  • Using the plastic opening tools, insert it into the edge and pry open.
  • Use hands to help pull the back off from the front if needed.
Aggiungi Commento
Locate CON2002
  • Locate CON2002
    • Check water indicator on USB Charging Port
  • A white indicator means there is no water damage. A red indicator means there was water damage.
Aggiungi Commento
  • Locate and remove three Phillips screws
Aggiungi Commento
  • Use a pair of tweezers to disconnect E893821
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Daniel
Membro da: 07/10/2014
308 Reputazione
2 Guide realizzate
USF Tampa, Team 7-4, Leahy Fall 2014 Membro di USF Tampa, Team 7-4, Leahy Fall 2014
USFT-LEAHY-F14S7G4
4 Membri
8 Guide realizzate
Does anyone have any idea where a replacement USB port can be found. Mine isnt water damaged but rather one of the pins broke off and its hanging out of the cable. Now the phone will not charge.
rich - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 23
Tutti i Tempi: 2,118
