Salta al contenuto principale
ASUS PadFone X Station Docking Connector Replacement
Cosa ti serve
  1. ASUS PadFone X Station Docking Connector Replacement, Back Cover: passo 1, immagine 1 di 2 ASUS PadFone X Station Docking Connector Replacement, Back Cover: passo 1, immagine 2 di 2
    • Using the plastic opening tools, insert it into the edge and pry open.
    • Use hands to help pull the back off from the front if needed.
  2. ASUS PadFone X Station Docking Connector Replacement, USB connector: passo 2, immagine 1 di 2 ASUS PadFone X Station Docking Connector Replacement, USB connector: passo 2, immagine 2 di 2
    • Locate the CON101
    • The white sticker indicates water exposure. White=none, Red=Exposure
  3. ASUS PadFone X Station Docking Connector Replacement, Remove two Phillips screws: passo 3, immagine 1 di 1
    • Remove two Phillips screws
  4. ASUS PadFone X Station Docking Connector Replacement, Locate P92L on CON1504: passo 4, immagine 1 di 2 ASUS PadFone X Station Docking Connector Replacement, Locate P92L on CON1504: passo 4, immagine 2 di 2
    • Locate P92L on CON1504
    • Gently peel back and remove plastic tape
  5. ASUS PadFone X Station Docking Connector Replacement, Removal of P92L: passo 5, immagine 1 di 3 ASUS PadFone X Station Docking Connector Replacement, Removal of P92L: passo 5, immagine 2 di 3 ASUS PadFone X Station Docking Connector Replacement, Removal of P92L: passo 5, immagine 3 di 3
    • Gently Pull P92L With Fingers From CON1504
  6. ASUS PadFone X Station Docking Connector Replacement, Identification of Antenna Wires: passo 6, immagine 1 di 1
    • These are the antenna wires.
    • Trace these wires to locate the two antennas.
  7. ASUS PadFone X Station Docking Connector Replacement, Desolder the two antenna wires: passo 7, immagine 1 di 2 ASUS PadFone X Station Docking Connector Replacement, Desolder the two antenna wires: passo 7, immagine 2 di 2
    • Locate the two antennas
    • Desolder the two antenna wires
Conclusione
Daniel
Membro da: 10/07/14
338 Reputazione
2 Guide realizzate
USF Tampa, Team 7-4, Leahy Fall 2014 Membro di USF Tampa, Team 7-4, Leahy Fall 2014
USFT-LEAHY-F14S7G4
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,423
