Salta al contenuto principale
ASUS PadFone X Station Battery Replacement
Cosa ti serve
  1. ASUS PadFone X Station Battery Replacement, Back Cover: passo 1, immagine 1 di 2 ASUS PadFone X Station Battery Replacement, Back Cover: passo 1, immagine 2 di 2
    • Using the plastic opening tools, insert it into the edge and pry open.
    • Use hands to help pull the back off from the front if needed.
  2. ASUS PadFone X Station Battery Replacement, Finding the Battery: passo 2, immagine 1 di 1
    • Locate 4600mAh Battery
  3. ASUS PadFone X Station Battery Replacement, Removing the Protective Cover: passo 3, immagine 1 di 2 ASUS PadFone X Station Battery Replacement, Removing the Protective Cover: passo 3, immagine 2 di 2
    • Locate (+) and (-) battery terminals
    • Trace black, white, red, and yellow wires to connection on motherboard
    • Remove protective plastic cover with tweezers
  4. ASUS PadFone X Station Battery Replacement, Disconnecting the Ribbon: passo 4, immagine 1 di 1
    • Disconnect connect ribbon by gently pulling with fingers
    • Ensure the ribbon does not touch metallic items (This may short out battery and cause an explosion)
  5. ASUS PadFone X Station Battery Replacement, Removing the Screws: passo 5, immagine 1 di 2 ASUS PadFone X Station Battery Replacement, Removing the Screws: passo 5, immagine 2 di 2
    • Remove (4) screws
  6. ASUS PadFone X Station Battery Replacement, Taking out the Battery: passo 6, immagine 1 di 3 ASUS PadFone X Station Battery Replacement, Taking out the Battery: passo 6, immagine 2 di 3 ASUS PadFone X Station Battery Replacement, Taking out the Battery: passo 6, immagine 3 di 3
    • Gently pry battery off glued surface
    • Use of a plastic opening tools and a spudger are necessary
Conclusione
Altre 5 persone hanno completato questa guida.
Paul Wagner
Membro da: 10/07/14
545 Reputazione
2 Guide realizzate
USF Tampa, Team 7-4, Leahy Fall 2014 Membro di USF Tampa, Team 7-4, Leahy Fall 2014
USFT-LEAHY-F14S7G4
4 Membri
8 Guide realizzate
3 Commenti
where can i find a battery for that station pls?
francidorio - Replica
Hello dear. Thanks for the tutorial on how to change the Padfone X tablet battery.
I have the Padfone x station without the cell phone because unfortunately my students have stolen it from me in the classroom while attending a mother (in Cordoba, Argentina).
I would like to know, then, if I could adapt an Asus cell phone model by changing the slot in the cell phone and / or in the tablet station in the back where both devices are embedded, so, what kind of spare parts should buy, and with which name to ask.
Since a thousand and one thanks. Best regards from Cordoba, Argentina.
Clara.
calejanmm - Replica
The proper battery for this unit is C11P1323.
acg - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 3,643
