Salta al contenuto principale
ASUS PadFone X Rear Facing Camera Replacement
Cosa ti serve
  1. ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: passo 1, immagine 1 di 2 ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: passo 1, immagine 2 di 2
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upward.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: passo 2, immagine 1 di 3 ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: passo 2, immagine 2 di 3 ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: passo 2, immagine 3 di 3
    • Remove the thirteen 3.6 mm screws using the torx T5 bit in the screwdriver.
  3. ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: passo 3, immagine 1 di 2 ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: passo 3, immagine 2 di 2
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera connector.: passo 4, immagine 1 di 1
    • Use the blue plastic opening tool to gently pry the camera connector up from its socket on the motherboard.
    • Applying too much force may damage the connector.
  5. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera.: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using the tweezers, remove the rear camera from the Padfone X.
    • The camera is lightly glued to the motherboard. You may need to use a plastic opening tool to loosen the adhesive under the camera.
  6. ASUS PadFone X Rear Facing Camera Replacement, Replacing the camera.: passo 6, immagine 1 di 1
    • Once the camera has been pulled out, replace the old camera with a new camera.
Conclusione
nestor
Membro da: 10/07/14
101 Reputazione
1 Guida realizzata
USF Tampa, Team 8-4, Leahy Fall 2014 Membro di USF Tampa, Team 8-4, Leahy Fall 2014
USFT-LEAHY-F14S8G4
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 539
