Salta al contenuto principale
ASUS PadFone X Battery Replacement
Cosa ti serve
  1. ASUS PadFone X Battery Replacement, Remove the back panel.: passo 1, immagine 1 di 2 ASUS PadFone X Battery Replacement, Remove the back panel.: passo 1, immagine 2 di 2
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Battery Replacement, Remove the screws.: passo 2, immagine 1 di 2 ASUS PadFone X Battery Replacement, Remove the screws.: passo 2, immagine 2 di 2
    • Remove the 13 - 3.6 mm screws using the Torx T5 bit in the screwdriver.
  3. ASUS PadFone X Battery Replacement, Remove the Mid-Frame: passo 3, immagine 1 di 2 ASUS PadFone X Battery Replacement, Remove the Mid-Frame: passo 3, immagine 2 di 2
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Battery Replacement, Remove the Battery Connector: passo 4, immagine 1 di 2 ASUS PadFone X Battery Replacement, Remove the Battery Connector: passo 4, immagine 2 di 2
    • Using the blue plastic opening tool, gently disconnect the battery cable from the motherboard.
    • Applying too much force may damage the connector.
  5. ASUS PadFone X Battery Replacement, Remove the battery.: passo 5, immagine 1 di 2 ASUS PadFone X Battery Replacement, Remove the battery.: passo 5, immagine 2 di 2
    • Use the blue plastic opening tool to pry the battery pack from the phone. Pry along edge away from the motherboard as this might damage the motherboard.
    • The battery pack is held on by double sided tape, you will have to apply some force when prying out the battery.
Conclusione
Altre 4 persone hanno completato questa guida.
John Kue
Membro da: 10/07/14
379 Reputazione
2 Guide realizzate
USF Tampa, Team 8-4, Leahy Fall 2014 Membro di USF Tampa, Team 8-4, Leahy Fall 2014
USFT-LEAHY-F14S8G4
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 5,136
