Salta al contenuto principale
ASUS N56JR-MH71 Optical Drive Replacement
Cosa ti serve
  1. ASUS N56JR-MH71 Optical Drive Replacement, Battery: passo 1, immagine 1 di 2 ASUS N56JR-MH71 Optical Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Push the battery latch.
  2. ASUS N56JR-MH71 Optical Drive Replacement: passo 2, immagine 1 di 1
    • Keep the battery latch held while you remove the battery.
  3. ASUS N56JR-MH71 Optical Drive Replacement, Optical Drive: passo 3, immagine 1 di 1
    • Remove the one screw above the battery port.
    • This device was missing its screws on the back cover when we received the device. As a result, we do not know what head type the screws are, along with their lengths.
  4. ASUS N56JR-MH71 Optical Drive Replacement: passo 4, immagine 1 di 1
    • Use a metal spudger to dislodge the optical drive from the connector.
  5. ASUS N56JR-MH71 Optical Drive Replacement: passo 5, immagine 1 di 1
    • Pull out the optical drive.
Conclusione
Ruben Lopez
Membro da: 11/05/18
399 Reputazione
4 Guide realizzate
IUPUI, Team S1-G4, Baechle Fall 2018 Membro di IUPUI, Team S1-G4, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G4
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 435
