Salta al contenuto principale
ASUS N550JK-DS71T Laptop RAM stick Replacement
Cosa ti serve
  1. ASUS N550JK-DS71T Laptop RAM stick Replacement, Back Case: passo 1, immagine 1 di 2 ASUS N550JK-DS71T Laptop RAM stick Replacement, Back Case: passo 1, immagine 2 di 2
    • Turn the laptop off and unplug all cables.
    • Flip over so the bottom is facing you.
    • Remove the ten 3mm Torx T5 screws from the bottom cover.
  2. ASUS N550JK-DS71T Laptop RAM stick Replacement: passo 2, immagine 1 di 2 ASUS N550JK-DS71T Laptop RAM stick Replacement: passo 2, immagine 2 di 2
    • Use a spudger to wedge between the laptop and bottom cover—lift upwards to pry open.
    • Run the spudger along the perimeter of the bottom cover to remove.
  3. ASUS N550JK-DS71T Laptop RAM stick Replacement, Battery: passo 3, immagine 1 di 2 ASUS N550JK-DS71T Laptop RAM stick Replacement, Battery: passo 3, immagine 2 di 2
    • Remove the three 4mm JIS #0 screws from the battery.
  4. ASUS N550JK-DS71T Laptop RAM stick Replacement: passo 4, immagine 1 di 2 ASUS N550JK-DS71T Laptop RAM stick Replacement: passo 4, immagine 2 di 2
    • Using both hands, lift the battery vertically out of the device.
  5. ASUS N550JK-DS71T Laptop RAM stick Replacement, RAM Stick: passo 5, immagine 1 di 1
    • Put on anti-static wristband and attach clip-end to any metal screw insert.
    • The wristband is recommended when working closely with circuit boards due to potential static discharge.
  6. ASUS N550JK-DS71T Laptop RAM stick Replacement: passo 6, immagine 1 di 3 ASUS N550JK-DS71T Laptop RAM stick Replacement: passo 6, immagine 2 di 3 ASUS N550JK-DS71T Laptop RAM stick Replacement: passo 6, immagine 3 di 3
    • The RAM will be secured by two metal clips surrounded by white plastic.
    • Spread the metal clips and the RAM stick will pop up. Then gently remove the RAM stick.
Conclusione
Steven Hahn
Membro da: 01/29/18
884 Reputazione
6 Guide realizzate
USF Tampa, Team S5-G1, Passmore Spring 2018 Membro di USF Tampa, Team S5-G1, Passmore Spring 2018
USFT-PASSMORE-S18S5G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,178
