Salta al contenuto principale
ASUS N550JK-DS71T Laptop CD/DVD Drive Replacement
Cosa ti serve
  1. ASUS N550JK-DS71T Laptop CD/DVD Drive Replacement, Back Case: passo 1, immagine 1 di 2 ASUS N550JK-DS71T Laptop CD/DVD Drive Replacement, Back Case: passo 1, immagine 2 di 2
    • Turn the laptop off and unplug all cables.
    • Flip over so the bottom is facing you.
    • Remove the ten 3mm Torx T5 screws from the bottom cover.
  2. ASUS N550JK-DS71T Laptop CD/DVD Drive Replacement: passo 2, immagine 1 di 2 ASUS N550JK-DS71T Laptop CD/DVD Drive Replacement: passo 2, immagine 2 di 2
    • Use a spudger to wedge between the laptop and bottom cover—lift upwards to pry open.
    • Run the spudger along the perimeter of the bottom cover to remove.
  3. ASUS N550JK-DS71T Laptop CD/DVD Drive Replacement, CD/DVD Drive: passo 3, immagine 1 di 2 ASUS N550JK-DS71T Laptop CD/DVD Drive Replacement, CD/DVD Drive: passo 3, immagine 2 di 2
    • Remove the two 4mm black Phillips #1 screws from the top of the CD/DVD bracket.
    • Remove the single 4mm silver Phillips #1 screw from the bottom of the CD/DVD bracket.
    • Remove the CD/DVD bracket.
  4. ASUS N550JK-DS71T Laptop CD/DVD Drive Replacement: passo 4, immagine 1 di 2 ASUS N550JK-DS71T Laptop CD/DVD Drive Replacement: passo 4, immagine 2 di 2
    • Remove the single 4mm silver Phillips #1 screw.
  5. ASUS N550JK-DS71T Laptop CD/DVD Drive Replacement: passo 5, immagine 1 di 1
    • Slide the drive out of the laptop using both hands.
Conclusione
Altre 2 persone hanno completato questa guida.
Steven Hahn
Membro da: 01/29/18
884 Reputazione
6 Guide realizzate
USF Tampa, Team S5-G1, Passmore Spring 2018 Membro di USF Tampa, Team S5-G1, Passmore Spring 2018
USFT-PASSMORE-S18S5G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,150
