Salta al contenuto principale
ASUS MeMo Pad FHD10 Camera Replacement
Cosa ti serve
  1. ASUS MeMo Pad FHD10 Camera Replacement, Battery: passo 1, immagine 1 di 2 ASUS MeMo Pad FHD10 Camera Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure that the device is turned off as a precaution.
    • Unplug the charger and remove any memory card you may have in the device.
    • Wedge the plastic opening tool between the front and back cover on every side.
    • Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
    • Once disconnected, remove the back cover from the device screen.
  2. ASUS MeMo Pad FHD10 Camera Replacement: passo 2, immagine 1 di 2 ASUS MeMo Pad FHD10 Camera Replacement: passo 2, immagine 2 di 2
    • Remove the protective copper sticker and all tape fixed on the device.
    • Using tweezers, remove the ribbon cable from their connections attached to the motherboard.
    • While using the tweezers, make sure to use minimum force and precision to avoid damaging any components.
  3. ASUS MeMo Pad FHD10 Camera Replacement: passo 3, immagine 1 di 2 ASUS MeMo Pad FHD10 Camera Replacement: passo 3, immagine 2 di 2
    • Remove the four 2 mm Phillips #00 screws holding the battery tray in place.
  4. ASUS MeMo Pad FHD10 Camera Replacement: passo 4, immagine 1 di 3 ASUS MeMo Pad FHD10 Camera Replacement: passo 4, immagine 2 di 3 ASUS MeMo Pad FHD10 Camera Replacement: passo 4, immagine 3 di 3
    • Locate the battery cable attached to the motherboard. Using the same technique used on the ribbons, do the same with the battery.
    • Remove the battery from the device. Once removed, use the plastic tool to separate the metal frame from the battery.
    • When separating the metal frame, be sure to hold on in the center as the battery is two separate cells.
  5. ASUS MeMo Pad FHD10 Camera Replacement, Speakers: passo 5, immagine 1 di 1
    • Remove three screws using a Phillips #00 screwdriver.
  6. ASUS MeMo Pad FHD10 Camera Replacement: passo 6, immagine 1 di 1
    • The two speakers are located on opposite sides of the device. Both are long black pieces with connections to the motherboard.
    • Unplug the speaker cables from their connections on the motherboard gently by using tweezers.
  7. ASUS MeMo Pad FHD10 Camera Replacement: passo 7, immagine 1 di 3 ASUS MeMo Pad FHD10 Camera Replacement: passo 7, immagine 2 di 3 ASUS MeMo Pad FHD10 Camera Replacement: passo 7, immagine 3 di 3
    • Gently use your hands to remove the speakers.
  8. ASUS MeMo Pad FHD10 Camera Replacement, Motherboard: passo 8, immagine 1 di 1
    • Remove the five screws using a Phillips #00 screwdriver.
  9. ASUS MeMo Pad FHD10 Camera Replacement: passo 9, immagine 1 di 3 ASUS MeMo Pad FHD10 Camera Replacement: passo 9, immagine 2 di 3 ASUS MeMo Pad FHD10 Camera Replacement: passo 9, immagine 3 di 3
    • Carefully disconnect the cord that connects the on/off button to the motherboard
    • Peel back the electrical tape holding the connections of the motherboard down to the frame of the device.
  10. ASUS MeMo Pad FHD10 Camera Replacement: passo 10, immagine 1 di 1
    • Use your hands to remove the motherboard from the device.
  11. ASUS MeMo Pad FHD10 Camera Replacement, Front and Rear cameras.: passo 11, immagine 1 di 1
    • Identify the location of front and rear cameras on the motherboard.
  12. ASUS MeMo Pad FHD10 Camera Replacement: passo 12, immagine 1 di 2 ASUS MeMo Pad FHD10 Camera Replacement: passo 12, immagine 2 di 2
    • The front and rear cameras can be removed by pulling them out gently using hands.
Conclusione
Dmitry
Membro da: 01/21/15
391 Reputazione
3 Guide realizzate
USF Tampa, Team 9-5, Blackwell Winter 2015 Membro di USF Tampa, Team 9-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G5
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 9
Tutti i Tempi: 566
