Salta al contenuto principale
ASUS MeMo Pad FHD10 Battery Replacement
Cosa ti serve
  1. ASUS MeMo Pad FHD10 Battery Replacement, Battery: passo 1, immagine 1 di 2 ASUS MeMo Pad FHD10 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure that the device is turned off as a precaution.
    • Unplug the charger and remove any memory card you may have in the device.
    • Wedge the plastic opening tool between the front and back cover on every side.
    • Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
    • Once disconnected, remove the back cover from the device screen.
  2. ASUS MeMo Pad FHD10 Battery Replacement: passo 2, immagine 1 di 2 ASUS MeMo Pad FHD10 Battery Replacement: passo 2, immagine 2 di 2
    • Remove the protective copper sticker and all tape fixed on the device.
    • Using tweezers, remove the ribbon cable from their connections attached to the motherboard.
    • While using the tweezers, make sure to use minimum force and precision to avoid damaging any components.
  3. ASUS MeMo Pad FHD10 Battery Replacement: passo 3, immagine 1 di 2 ASUS MeMo Pad FHD10 Battery Replacement: passo 3, immagine 2 di 2
    • Remove the four 2 mm Phillips #00 screws holding the battery tray in place.
  4. ASUS MeMo Pad FHD10 Battery Replacement: passo 4, immagine 1 di 3 ASUS MeMo Pad FHD10 Battery Replacement: passo 4, immagine 2 di 3 ASUS MeMo Pad FHD10 Battery Replacement: passo 4, immagine 3 di 3
    • Locate the battery cable attached to the motherboard. Using the same technique used on the ribbons, do the same with the battery.
    • Remove the battery from the device. Once removed, use the plastic tool to separate the metal frame from the battery.
    • When separating the metal frame, be sure to hold on in the center as the battery is two separate cells.
Conclusione
Altre 5 persone hanno completato questa guida.
Dmitry
Membro da: 01/21/15
391 Reputazione
3 Guide realizzate
USF Tampa, Team 9-5, Blackwell Winter 2015 Membro di USF Tampa, Team 9-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G5
4 Membri
10 Guide realizzate
Un commento
Where i can get new battery for this tablet?
Night Knight - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 15
Tutti i Tempi: 9,676
