Salta al contenuto principale
ASUS K53E-BBR1 Keyboard Replacement
Cosa ti serve
  1. ASUS K53E-BBR1 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Lift the monitor up so that the keyboard is visible.
    • You will notice five spots on the top of the keyboard where the iFixit opening tool should be placed.
  2. ASUS K53E-BBR1 Keyboard Replacement: passo 2, immagine 1 di 3 ASUS K53E-BBR1 Keyboard Replacement: passo 2, immagine 2 di 3 ASUS K53E-BBR1 Keyboard Replacement: passo 2, immagine 3 di 3
    • Use the iFixit opening tool on each of the designated spots to pry the keyboard apart from the palm rest.
    • You will hear a light "pop" sound each time you pry the keyboard.
    • Once the keyboard is loose, do not pull keyboard far (more than 3 inches) apart from the from the palm rest. There is a "bus" connector attached to the bottom.
  3. ASUS K53E-BBR1 Keyboard Replacement: passo 3, immagine 1 di 1
    • Carefully disconnect the "bus" connector from the laptop. Press on it with your thumb/index finger and slide it right along the surface of the laptop.
Conclusione
Paulo Fortes
Membro da: 03/20/19
147 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 417
