Introduzione
Sometimes screens stop working. This guide will show you how to replace your screen and get back to browsing.
Cosa ti serve
Slide the tab over to unlock the battery cover located on the bottom-left corner of the laptop.
Using the PH1 screwdriver, remove the four 4 .75 mm screws that are located on the vent panel.
Using the PH1 screwdriver remove the two .75 mm screws from the hinge side of the laptop.
Using a metal spudger, pop off the six rubber screw covers.
3 Commenti
Thank you for your time!
Now, I donĀ“t know how to connect the cables to the motherboard because they are too short.
