Introduzione
Keyboard replacements for an Asus K200MA 11.6" can be done easily with this step-by-step guide. This island-style keyboard is compatible with 1.5mm keys within a 1.5-2mm range.
Cosa ti serve
With the opening facing you, flip the laptop over and remove the following screws from the back panel:
Six 4mm Phillips screws using a Phillips #0 screwdriver.
One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
To disconnect the keyboard connectors from keyboard and back panel, gently pull wide keyboard connector out.
Gently pull the narrow connector away from the keyboard.
