Salta al contenuto principale
ASUS K200MA-DS01T Keyboard Replacement
Cosa ti serve
  1. ASUS K200MA-DS01T Keyboard Replacement, Back Panel: passo 1, immagine 1 di 2 ASUS K200MA-DS01T Keyboard Replacement, Back Panel: passo 1, immagine 2 di 2
    • With the opening facing you, flip the laptop over and remove the following screws from the back panel:
    • Six 4mm Phillips screws using a Phillips #0 screwdriver.
    • One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
  2. ASUS K200MA-DS01T Keyboard Replacement: passo 2, immagine 1 di 2 ASUS K200MA-DS01T Keyboard Replacement: passo 2, immagine 2 di 2
    • Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
  3. ASUS K200MA-DS01T Keyboard Replacement: passo 3, immagine 1 di 1
    • Remove the following screws:
    • Two 4mm Phillips screws using a Phillips #0 screwdriver.
  4. ASUS K200MA-DS01T Keyboard Replacement: passo 4, immagine 1 di 3 ASUS K200MA-DS01T Keyboard Replacement: passo 4, immagine 2 di 3 ASUS K200MA-DS01T Keyboard Replacement: passo 4, immagine 3 di 3
    • Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
    • You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
  5. ASUS K200MA-DS01T Keyboard Replacement, Keyboard: passo 5, immagine 1 di 2 ASUS K200MA-DS01T Keyboard Replacement, Keyboard: passo 5, immagine 2 di 2
    • To disconnect the keyboard connectors from keyboard and back panel, gently pull wide keyboard connector out.
    • Gently pull the narrow connector away from the keyboard.
  6. ASUS K200MA-DS01T Keyboard Replacement: passo 6, immagine 1 di 2 ASUS K200MA-DS01T Keyboard Replacement: passo 6, immagine 2 di 2
    • Now that the keyboard connectors are unplugged, pull the keyboard off and away from the back panel hinges.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 169
