Salta al contenuto principale
ASUS K200MA-DS01T Hard Drive Replacement
Cosa ti serve
  1. ASUS K200MA-DS01T Hard Drive Replacement, Back Panel: passo 1, immagine 1 di 2 ASUS K200MA-DS01T Hard Drive Replacement, Back Panel: passo 1, immagine 2 di 2
    • With the opening facing you, flip the laptop over and remove the following screws from the back panel:
    • Six 4mm Phillips screws using a Phillips #0 screwdriver.
    • One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
  2. ASUS K200MA-DS01T Hard Drive Replacement: passo 2, immagine 1 di 2 ASUS K200MA-DS01T Hard Drive Replacement: passo 2, immagine 2 di 2
    • Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
  3. ASUS K200MA-DS01T Hard Drive Replacement: passo 3, immagine 1 di 1
    • Remove the following screws:
    • Two 4mm Phillips screws using a Phillips #0 screwdriver.
  4. ASUS K200MA-DS01T Hard Drive Replacement: passo 4, immagine 1 di 3 ASUS K200MA-DS01T Hard Drive Replacement: passo 4, immagine 2 di 3 ASUS K200MA-DS01T Hard Drive Replacement: passo 4, immagine 3 di 3
    • Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
    • You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
  5. ASUS K200MA-DS01T Hard Drive Replacement, Keyboard: passo 5, immagine 1 di 2 ASUS K200MA-DS01T Hard Drive Replacement, Keyboard: passo 5, immagine 2 di 2
    • To disconnect the keyboard connectors from keyboard and back panel, gently pull wide keyboard connector out.
    • Gently pull the narrow connector away from the keyboard.
  6. ASUS K200MA-DS01T Hard Drive Replacement: passo 6, immagine 1 di 2 ASUS K200MA-DS01T Hard Drive Replacement: passo 6, immagine 2 di 2
    • Now that the keyboard connectors are unplugged, pull the keyboard off and away from the back panel hinges.
  7. ASUS K200MA-DS01T Hard Drive Replacement, Battery: passo 7, immagine 1 di 2 ASUS K200MA-DS01T Hard Drive Replacement, Battery: passo 7, immagine 2 di 2
    • Flip the computer over so that the side with the motherboard (large green piece) is laying face-up.
    • Remove the following screws from the middle and far ends of the battery:
    • Three 4mm Phillips screws using a Phillips #0 screwdriver.
    • The battery will be located closest to the screen.
  8. ASUS K200MA-DS01T Hard Drive Replacement: passo 8, immagine 1 di 3 ASUS K200MA-DS01T Hard Drive Replacement: passo 8, immagine 2 di 3 ASUS K200MA-DS01T Hard Drive Replacement: passo 8, immagine 3 di 3
    • Gripping the wider left section, lift the battery up and away from computer.
  9. ASUS K200MA-DS01T Hard Drive Replacement, Fan: passo 9, immagine 1 di 2 ASUS K200MA-DS01T Hard Drive Replacement, Fan: passo 9, immagine 2 di 2
    • Locate the fan, two screws and two color coded wires in the bottom left corner of the computer.
  10. ASUS K200MA-DS01T Hard Drive Replacement: passo 10, immagine 1 di 1
    • Remove the following screws from the fan:
    • Two 4mm screws using a Phillips #0 screwdriver.
  11. ASUS K200MA-DS01T Hard Drive Replacement: passo 11, immagine 1 di 2 ASUS K200MA-DS01T Hard Drive Replacement: passo 11, immagine 2 di 2
    • Firmly pull colored wires away from wire slot.
  12. ASUS K200MA-DS01T Hard Drive Replacement: passo 12, immagine 1 di 2 ASUS K200MA-DS01T Hard Drive Replacement: passo 12, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • After removing both the screws and color coded wires, lift fan out of place.
    • Tools such as spudgers or tweezers may be used for fan removal.
  13. ASUS K200MA-DS01T Hard Drive Replacement, Hard drive: passo 13, immagine 1 di 2 ASUS K200MA-DS01T Hard Drive Replacement, Hard drive: passo 13, immagine 2 di 2
    • Four 4mm Phillips screws using a Phillips #0 screwdriver.
  14. ASUS K200MA-DS01T Hard Drive Replacement: passo 14, immagine 1 di 2 ASUS K200MA-DS01T Hard Drive Replacement: passo 14, immagine 2 di 2
    • Remove by sliding hard driving right and away from the computer using the tag on the right side.
Conclusione
Terrinda
Membro da: 09/17/18
526 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 494
