Introduzione
If you suspect your ASUS G73JH-BST7, or ASUS G73 Gaming Series Laptop, is malfunctioning because of hardware issues, you will need to remove the back panel to investigate.
Make sure to power down your device before you begin.
Cosa ti serve
With the bottom of the computer facing up, remove the two 7.1 mm screws using a Phillips #00 screwdriver.
Quasi finito!
Conclusione
