Salta al contenuto principale
ASUS G713RC RAM Replacement
Cosa ti serve
  1. ASUS G713RC RAM Replacement, RAM: passo 1, immagine 1 di 3 ASUS G713RC RAM Replacement, RAM: passo 1, immagine 2 di 3 ASUS G713RC RAM Replacement, RAM: passo 1, immagine 3 di 3
    • Warning: Do not touch any other components inside if you don't have to. It may result in damage and can destroy your laptop.
    • Remove the seven large screws using a Phillips #00 screwdriver.
    • Remove the four small screws using a Phillips #00 screwdriver.
    • Carefully lift the lid, being careful of the two cables connected to the laptop.
  2. ASUS G713RC RAM Replacement: passo 2, immagine 1 di 3 ASUS G713RC RAM Replacement: passo 2, immagine 2 di 3 ASUS G713RC RAM Replacement: passo 2, immagine 3 di 3
    • Carefully detach the two white cables that are connected to the lid.
    • Set aside the lid.
  3. ASUS G713RC RAM Replacement: passo 3, immagine 1 di 3 ASUS G713RC RAM Replacement: passo 3, immagine 2 di 3 ASUS G713RC RAM Replacement: passo 3, immagine 3 di 3
    • Carefully lift up each gray bar.
    • It is important that you don't completely remove the gray bar.
    • Remove the RAM.
  4. ASUS G713RC RAM Replacement: passo 4, immagine 1 di 3 ASUS G713RC RAM Replacement: passo 4, immagine 2 di 3 ASUS G713RC RAM Replacement: passo 4, immagine 3 di 3
    • Insert each RAM stick under the gray bar. Push until you hear a click.
    • Hold down the gray bar to make sure it is flat and secure.
    • It might be a bit bumpy, but it is nothing to worry about.
  5. ASUS G713RC RAM Replacement: passo 5, immagine 1 di 2 ASUS G713RC RAM Replacement: passo 5, immagine 2 di 2
    • Reattach the lid by connecting the white wires to the base.
    • Plug in the white wires on both sides. You want to plug them in thoroughly, otherwise, your laptop won't turn on.
  6. ASUS G713RC RAM Replacement: passo 6, immagine 1 di 2 ASUS G713RC RAM Replacement: passo 6, immagine 2 di 2
    • Line up the lid to the laptop.
    • Tighten the seven large screws using a Phillips #00 screwdriver.
    • Tighten the four small screws using a Phillips #00 screwdriver.
Linea Traguardo
Javier Bobadilla
Membro da: 10/23/24
157 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 150
Tutti i Tempi: 242
