Introduzione
In this guide, I will show you how to replace a RAM in an ASUS G713RC laptop. It may seem like a hard replacement at first look, but it will be fairly simple and not time consuming. Not replacing your RAM in time may cause issues to your laptop so it is important to replace it as soon as possible. No worries! This guide will help you replace one.
Hazard Warning: If you have small children, please do not leave any small parts from the laptop that can be easy access to the child. It can be a choking hazard.
Cosa ti serve
Remove the seven large screws using a Phillips #00 screwdriver.
Remove the four small screws using a Phillips #00 screwdriver.
Carefully lift the lid, being careful of the two cables connected to the laptop.
Altre 2 persone hanno completato questa guida.
