Salta al contenuto principale
Cosa ti serve
  1. ASUS F555UA-EH71 Battery Replacement, Keyboard Panel: passo 1, immagine 1 di 1
    • Remove the ten 18 mm screws holding down the outer shell of the laptop using the Phillips #000 screwdriver.
  2. ASUS F555UA-EH71 Battery Replacement: passo 2, immagine 1 di 2 ASUS F555UA-EH71 Battery Replacement: passo 2, immagine 2 di 2
    • Use your fingers to gently pry open the gap between the silver and black parts of the casing.
    • Separate the keyboard panel from the body of the laptop by wedging the iFixit Opening Tool in between the keyboard panel and the body.
    • The teeth of the casing should make a clicking noise as they’re pulled apart.
  3. ASUS F555UA-EH71 Battery Replacement: passo 3, immagine 1 di 1
    • Gently open the casing until the white, silver, and gold power strips are visible. Gently peel the strips from the bottom side of the laptop.
    • Disconnect the two cables connecting the keyboard panel to the laptop.
  4. ASUS F555UA-EH71 Battery Replacement: passo 4, immagine 1 di 1
    • Remove the keyboard panel from the laptop.
  5. ASUS F555UA-EH71 Battery Replacement, Battery: passo 5, immagine 1 di 3 ASUS F555UA-EH71 Battery Replacement, Battery: passo 5, immagine 2 di 3 ASUS F555UA-EH71 Battery Replacement, Battery: passo 5, immagine 3 di 3
    • Use the Phillips #000 screwdriver to remove the eight 4 mm screws holding the battery in place.
  6. ASUS F555UA-EH71 Battery Replacement: passo 6, immagine 1 di 2 ASUS F555UA-EH71 Battery Replacement: passo 6, immagine 2 di 2
    • Carefully remove the battery from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 674
