Salta al contenuto principale
ASUS F550 Wifi Card Replacement
Cosa ti serve
  1. ASUS F550 Wifi Card Replacement, ASUS F550 HDD/Ram Cover Removal: passo 1, immagine 1 di 2 ASUS F550 Wifi Card Replacement, ASUS F550 HDD/Ram Cover Removal: passo 1, immagine 2 di 2
    • Remove the battery, using release clips.
    • Ensure device has no residual power by attempting boot once battery is removed.
    • Remove either 2 (or 4 for a full teardown) 12mm phillips screws, then removing the bottom cover to gain access to the HDD and RAM.
    • Remove HDD and RAM cover
  2. ASUS F550 Wifi Card Replacement, HDD: passo 2, immagine 1 di 1
    • Remove 3 5mm Phillips screws
    • Slide HDD caddy back, remove using the black pull tab.
  3. ASUS F550 Wifi Card Replacement, HDD Removal from Caddy: passo 3, immagine 1 di 1
    • Remove 4 Phillips screws, 2 per side
    • Remove HDD from caddy.
  4. ASUS F550 Wifi Card Replacement, Keyboard: passo 4, immagine 1 di 1
    • Remove 7 5mm Phillips screws
  5. ASUS F550 Wifi Card Replacement: passo 5, immagine 1 di 3 ASUS F550 Wifi Card Replacement: passo 5, immagine 2 di 3 ASUS F550 Wifi Card Replacement: passo 5, immagine 3 di 3
    • Flip laptop and open lid. Separate the keyboard plate from the main housing, using a plastic prying tool. Being careful not to damage the LED indicators or other peripheries.
    • Disconnect the LED, trackpad, and keyboard ribbon cables.
    • The keyboard can now be removed
  6. ASUS F550 Wifi Card Replacement, Wifi Card: passo 6, immagine 1 di 2 ASUS F550 Wifi Card Replacement, Wifi Card: passo 6, immagine 2 di 2
    • Locate Wifi Card
    • Remove the antenna cables using a spudger tool.
    • Remove the Philips screw The Wifi Card will pop up and should be easily removed.
Conclusione
Altre 4 persone hanno completato questa guida.
Ryan
Membro da: 08/19/15
1.519 Reputazione
14 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 51
Tutti i Tempi: 7,234
