Salta al contenuto principale
ASUS Eee Pad Transformer Back Panel Replacement
Cosa ti serve
  1. ASUS Eee Pad Transformer Back Panel Replacement, Back Panel: passo 1, immagine 1 di 2 ASUS Eee Pad Transformer Back Panel Replacement, Back Panel: passo 1, immagine 2 di 2
    • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
  2. ASUS Eee Pad Transformer Back Panel Replacement: passo 2, immagine 1 di 3 ASUS Eee Pad Transformer Back Panel Replacement: passo 2, immagine 2 di 3 ASUS Eee Pad Transformer Back Panel Replacement: passo 2, immagine 3 di 3
    • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
    • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  3. ASUS Eee Pad Transformer Back Panel Replacement: passo 3, immagine 1 di 1
    • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
  4. ASUS Eee Pad Transformer Back Panel Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
  5. ASUS Eee Pad Transformer Back Panel Replacement: passo 5, immagine 1 di 1
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
  6. ASUS Eee Pad Transformer Back Panel Replacement: passo 6, immagine 1 di 2 ASUS Eee Pad Transformer Back Panel Replacement: passo 6, immagine 2 di 2
    • Remove back panel by pulling away from the remaining device.
Conclusione
Altre 4 persone hanno completato questa guida.
Sandy Babich
Membro da: 09/23/14
1.885 Reputazione
5 Guide realizzate
Cal Poly, Team 13-9, Forte Fall 2014 Membro di Cal Poly, Team 13-9, Forte Fall 2014
CPSU-FORTE-F14S13G9
5 Membri
12 Guide realizzate
Un commento
what can I use to stick back the metalic edge?
Cathy Madzimure - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 3,881
