1. Lay the laptop flat on a hard surface with the bottom facing up and the battery pack on the side closest to you.
    • Lay the laptop flat on a hard surface with the bottom facing up and the battery pack on the side closest to you.
  2. Use both index fingers to push both spring tabs inwards towards the center of the laptop.
    • Use both index fingers to push both spring tabs inwards towards the center of the laptop.
    • With the spring tabs pressed inward, use your fingernails to lift of the edge of the battery, pivoting it up and towards you.
    • Pull the battery pack up and away from you to completely free it from its recess in the case.
Conclusione
Altre 2 persone hanno completato questa guida.
Daniel Rodman
Membro da: 20/01/2012
246 Reputazione
2 Guide realizzate
Cal Poly, Team 8-13, Maness Winter 2012 Membro di Cal Poly, Team 8-13, Maness Winter 2012
CPSU-MANESS-W12S8G13
4 Membri
5 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,120
