Salta al contenuto principale
ASUS EEE PC701SD-WHI004X Keyboard Replacement
Cosa ti serve
  1. ASUS EEE PC701SD-WHI004X Keyboard Replacement, Battery: passo 1, immagine 1 di 2 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the laptop over, you should see two battery tabs.
    • Slide the right tab towards the right. The orange dot should be visible. This tab will be locked open.
  2. ASUS EEE PC701SD-WHI004X Keyboard Replacement: passo 2, immagine 1 di 2 ASUS EEE PC701SD-WHI004X Keyboard Replacement: passo 2, immagine 2 di 2
    • While holding the left tab towards the left. Gently slide the battery out of the laptop.
  3. ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: passo 3, immagine 1 di 3 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: passo 3, immagine 2 di 3 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: passo 3, immagine 3 di 3
    • Push the 3 tabs at the top of the keyboard in and down one at a time using a nylon spudger.
    • Once the three tabs have been pushed in, gently pry the top of the keyboard until it begins to hinge out of its slot.
    • The keyboard is still attached by a cable. Be careful when removing not to damage the cable. Do not yank the keyboard out.
  4. ASUS EEE PC701SD-WHI004X Keyboard Replacement: passo 4, immagine 1 di 3 ASUS EEE PC701SD-WHI004X Keyboard Replacement: passo 4, immagine 2 di 3 ASUS EEE PC701SD-WHI004X Keyboard Replacement: passo 4, immagine 3 di 3
    • Push the two sides of the ribbon cable connector away from yourself. This will unseat the ribbon cable.
    • Once the tabs are unseated, you can gently remove the ribbon cable by pulling it out of its slot. The keyboard can now be removed.
    • To be on the safe side, it’s better to use a nylon spudger, rather than the metal spudger shown in the picture.
Conclusione
mir
Membro da: 03/24/17
409 Reputazione
3 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 704
