Salta al contenuto principale
ASUS E210MA-TB.CL464BK Battery Replacement
Cosa ti serve
  1. ASUS E210MA-TB.CL464BK Battery Replacement, Battery: passo 1, immagine 1 di 3 ASUS E210MA-TB.CL464BK Battery Replacement, Battery: passo 1, immagine 2 di 3 ASUS E210MA-TB.CL464BK Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Place the laptop with the bottom side facing up. Have the front (where the mousepad is) facing toward you.
    • Start by removing the ten 7mm screws on the bottom of the laptop using a JIS #00 JIS screwdriver.
  2. ASUS E210MA-TB.CL464BK Battery Replacement: passo 2, immagine 1 di 1
    • Double-check to make sure all of the screws are removed.
    • If you have a Jimmy or other flat, straight-edge object, slide it in the crack where the halves of the case meet.
    • When the parts are separated, pull them apart to expose the insides of the case.
  3. ASUS E210MA-TB.CL464BK Battery Replacement: passo 3, immagine 1 di 2 ASUS E210MA-TB.CL464BK Battery Replacement: passo 3, immagine 2 di 2
    • Remove the 4 mm screws around the USB port.
  4. ASUS E210MA-TB.CL464BK Battery Replacement: passo 4, immagine 1 di 2 ASUS E210MA-TB.CL464BK Battery Replacement: passo 4, immagine 2 di 2
    • Remove the 3 mm screws around the battery.
    • Carefully lift up the USB port and set it to the side.
  5. ASUS E210MA-TB.CL464BK Battery Replacement: passo 5, immagine 1 di 2 ASUS E210MA-TB.CL464BK Battery Replacement: passo 5, immagine 2 di 2
    • Unplug the connection between the motherboard and the battery by pulling towards the speaker side.
    • Repeat the same process to remove the blue tape on the second picture.
  6. ASUS E210MA-TB.CL464BK Battery Replacement: passo 6, immagine 1 di 1
    • Lift up and remove the battery.
Conclusione
John Hutchins
Membro da: 02/07/23
763 Reputazione
5 Guide realizzate
Gateway, Team 73-6, Gonzalez Spring 2023 Membro di Gateway, Team 73-6, Gonzalez Spring 2023
GCC-GONZALEZ-S23S73G6
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 34
Tutti i Tempi: 440
