Salta al contenuto principale
ASUS Chromebook C300MA-DH01 Battery Replacement
Cosa ti serve
  1. ASUS Chromebook C300MA-DH01 Battery  Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the Chromebook over so the bottom of the device is facing up.
  2. ASUS Chromebook C300MA-DH01 Battery  Replacement: passo 2, immagine 1 di 2 ASUS Chromebook C300MA-DH01 Battery  Replacement: passo 2, immagine 2 di 2
    • Using the JIS-J0 Screwdriver, remove the following screws from the bottom
    • (5) Five 6mm screws
    • (6) Six 8mm screws
  3. ASUS Chromebook C300MA-DH01 Battery  Replacement: passo 3, immagine 1 di 3 ASUS Chromebook C300MA-DH01 Battery  Replacement: passo 3, immagine 2 di 3 ASUS Chromebook C300MA-DH01 Battery  Replacement: passo 3, immagine 3 di 3
    • Gently wedge the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open. Then, carefully lift up on keyboard.
  4. ASUS Chromebook C300MA-DH01 Battery  Replacement: passo 4, immagine 1 di 3 ASUS Chromebook C300MA-DH01 Battery  Replacement: passo 4, immagine 2 di 3 ASUS Chromebook C300MA-DH01 Battery  Replacement: passo 4, immagine 3 di 3
    • Gently detach connecting cables:
    • Carefully flip up the large black tab.
    • Carefully flip up small white tab.
    • Remove the corresponding black cable.
    • Remove the corresponding white cable.
    • The keyboard will be fully detached at this point.
  5. ASUS Chromebook C300MA-DH01 Battery  Replacement: passo 5, immagine 1 di 2 ASUS Chromebook C300MA-DH01 Battery  Replacement: passo 5, immagine 2 di 2
    • Using the JIS-J0 Screwdriver, remove the (6) six 6 mm screws from the battery.
  6. ASUS Chromebook C300MA-DH01 Battery  Replacement: passo 6, immagine 1 di 1
    • Using the plastic opening tool, gently push the connector tab away from the battery to detach the cable.
    • The battery will be fully detached at this point. Carefully lift it out of the device.
Conclusione
amer khalil
Membro da: 09/26/17
101 Reputazione
1 Guida realizzata
USF Tampa, Team S2-G5, Passmore Fall 2017 Membro di USF Tampa, Team S2-G5, Passmore Fall 2017
USFT-PASSMORE-F17S2G5
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 216
