Introduzione
This guide will take you through a step-by-step process for the removal of your Chromebook’s USB board.
Cosa ti serve
Remove the five 8.4 mm Phillips #0 screws.
Remove the four 4.6 mm Phillips #0 screws.
To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
Disconnect the USB board ZIF (zero insertion force) connectors which connect the motherboard to the USB board in the upper left.
Flip the ZIF retaining flaps up using a plastic opening tool or your fingers.
Pull gently on the ribbon cable to disconnect it from the sockets.
