Salta al contenuto principale
ASUS Chromebook C200MA DS01 Touchpad Replacement
Cosa ti serve
  1. ASUS Chromebook C200MA DS01 Touchpad Replacement, Back Panel: passo 1, immagine 1 di 1
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 Touchpad Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 Touchpad Replacement: passo 3, immagine 1 di 1
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery Connection: passo 4, immagine 1 di 3 ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery Connection: passo 4, immagine 2 di 3 ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery Connection: passo 4, immagine 3 di 3
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery: passo 5, immagine 1 di 2 ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery: passo 5, immagine 2 di 2
    • Remove the four 4.7 mm Phillips #0 screws that secure the battery to the Chromebook.
  6. ASUS Chromebook C200MA DS01 Touchpad Replacement: passo 6, immagine 1 di 1
    • Pull out the battery.
  7. ASUS Chromebook C200MA DS01 Touchpad Replacement, Touchpad: passo 7, immagine 1 di 1
    • Locate the touchpad.
    • Locate the touch pad cable connector.
  8. ASUS Chromebook C200MA DS01 Touchpad Replacement: passo 8, immagine 1 di 3 ASUS Chromebook C200MA DS01 Touchpad Replacement: passo 8, immagine 2 di 3 ASUS Chromebook C200MA DS01 Touchpad Replacement: passo 8, immagine 3 di 3
    • Disconnect the touch pad ZIF(zero insertion force) connector.
    • Flip the flap up using a spudger or your fingers.
    • Pull gently on the ribbon cable to disconnect.
  9. ASUS Chromebook C200MA DS01 Touchpad Replacement: passo 9, immagine 1 di 1
    • Gently remove the adhesive on the touch pad ribbon cable.
  10. ASUS Chromebook C200MA DS01 Touchpad Replacement: passo 10, immagine 1 di 3 ASUS Chromebook C200MA DS01 Touchpad Replacement: passo 10, immagine 2 di 3 ASUS Chromebook C200MA DS01 Touchpad Replacement: passo 10, immagine 3 di 3
    • Gently remove the metallic tape from the touch pad only.
    • Try not to tear the tape, it can be re-used during reassembly.
  11. ASUS Chromebook C200MA DS01 Touchpad Replacement: passo 11, immagine 1 di 1
    • Remove the three 1.8 mm Phillips #00 screws.
  12. ASUS Chromebook C200MA DS01 Touchpad Replacement: passo 12, immagine 1 di 2 ASUS Chromebook C200MA DS01 Touchpad Replacement: passo 12, immagine 2 di 2
    • Lift the far edge of the touch pad to remove it.
Conclusione
Cal Poly, Team S23-G4, Livingston Spring 2017 Membro di Cal Poly, Team S23-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G4
4 Membri
19 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 592
