Salta al contenuto principale
ASUS Chromebook C200MA DS01 Speaker Replacement
Cosa ti serve
  1. ASUS Chromebook C200MA DS01 Speaker Replacement, Back Panel: passo 1, immagine 1 di 1
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 Speaker Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 Speaker Replacement: passo 3, immagine 1 di 1
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 Speaker Replacement, Battery Connection: passo 4, immagine 1 di 3 ASUS Chromebook C200MA DS01 Speaker Replacement, Battery Connection: passo 4, immagine 2 di 3 ASUS Chromebook C200MA DS01 Speaker Replacement, Battery Connection: passo 4, immagine 3 di 3
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 Speaker Replacement, Battery: passo 5, immagine 1 di 2 ASUS Chromebook C200MA DS01 Speaker Replacement, Battery: passo 5, immagine 2 di 2
    • Remove the four 4.7 mm Phillips #0 screws that secure the battery to the Chromebook.
  6. ASUS Chromebook C200MA DS01 Speaker Replacement: passo 6, immagine 1 di 1
    • Pull out the battery.
  7. ASUS Chromebook C200MA DS01 Speaker Replacement, Speaker: passo 7, immagine 1 di 2 ASUS Chromebook C200MA DS01 Speaker Replacement, Speaker: passo 7, immagine 2 di 2
    • Disconnect the speaker's black bundled cable connector on the motherboard.
    • The cables are red, white and black.
    • Pinch the black bundled cable connector between your thumb and pointer finger and pull.
  8. ASUS Chromebook C200MA DS01 Speaker Replacement: passo 8, immagine 1 di 2 ASUS Chromebook C200MA DS01 Speaker Replacement: passo 8, immagine 2 di 2
    • Using your hands or the small plastic opening tool, pry the right speaker from the Chromebook.
    • There are small adhesives under the speakers that will provide moderate resistance.
  9. ASUS Chromebook C200MA DS01 Speaker Replacement: passo 9, immagine 1 di 2 ASUS Chromebook C200MA DS01 Speaker Replacement: passo 9, immagine 2 di 2
    • Disconnect the USB port ZIF(zero insertion force) connector that partially covers the left speaker.
    • Flip the ZIF retaining flap up using a spudger or your fingers.
    • Pull gently on the ribbon cable to remove it from the connector.
  10. ASUS Chromebook C200MA DS01 Speaker Replacement: passo 10, immagine 1 di 2 ASUS Chromebook C200MA DS01 Speaker Replacement: passo 10, immagine 2 di 2
    • Unravel the connecting cord between the two speakers.
  11. ASUS Chromebook C200MA DS01 Speaker Replacement: passo 11, immagine 1 di 3 ASUS Chromebook C200MA DS01 Speaker Replacement: passo 11, immagine 2 di 3 ASUS Chromebook C200MA DS01 Speaker Replacement: passo 11, immagine 3 di 3
    • Using the small plastic opening tool, pry the left speaker from the Chromebook.
    • Remove the speakers.
    • There are small adhesives that will provide moderate resistance.
Conclusione
Cal Poly, Team S23-G4, Livingston Spring 2017 Membro di Cal Poly, Team S23-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G4
4 Membri
19 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 269
