Salta al contenuto principale
ASUS Chromebook C200MA DS01 Battery Replacement
Cosa ti serve
  1. ASUS Chromebook C200MA DS01 Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 Battery Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 Battery Replacement: passo 3, immagine 1 di 1
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 Battery Replacement, Battery Connection: passo 4, immagine 1 di 3 ASUS Chromebook C200MA DS01 Battery Replacement, Battery Connection: passo 4, immagine 2 di 3 ASUS Chromebook C200MA DS01 Battery Replacement, Battery Connection: passo 4, immagine 3 di 3
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 Battery Replacement, Battery: passo 5, immagine 1 di 2 ASUS Chromebook C200MA DS01 Battery Replacement, Battery: passo 5, immagine 2 di 2
    • Remove the four 4.7 mm Phillips #0 screws that secure the battery to the Chromebook.
  6. ASUS Chromebook C200MA DS01 Battery Replacement: passo 6, immagine 1 di 1
    • Pull out the battery.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S23-G4, Livingston Spring 2017 Membro di Cal Poly, Team S23-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G4
4 Membri
19 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 66
Tutti i Tempi: 13,378
